Wow that turned out really nice!! I may take you up on the visit once it is time to finalize my pavers. I was planning on going with travertine but the benefits of coral in the heat seem appealing. Was it around the same cost as travertine?
Arizona stone which is located on the west side of the strip by Tropicana has shell stone in stock and also has a display of it installed in the ground as well as every other type of stone you can think of. I highly recommend you check out this place when you make your stone and decking choices even if you don't buy there because they have EVERYTHING in there showroom. And the prices are extremely close on the two cause we almost went with the shell stone
Hope this helps
Hope this helps
