Stenner some questions
Yaniv
149
San Jose, CA
I have the rainbow 320 installed (new pool) i want to replace it with a Stenner 45MHP10.
Can i use the injection input already in use with the rainbow 320 with the Stenner? or do i need to redo it?
I have an Ecommand 4 with a VS pump, how to i connect the Stenner to the Ecommand 4 for power when the system is on?
You can use the attachment port of the 320 for the injection fitting of the Stenner, as long as you're removing the 320.
If you're not using Aux1 or Aux2 for anything else you can use one of them to run the injection pump. It can also be setup so that it won't energize unless the filter pump is running.
