Hi Cowboy.
If you want to fine tune your understanding of the cell's capabilities a bit better, here's how to figure out how much production its capable of in your pool.
Look up the rate production of your specific cell -- it will be x pounds of chlorine gas per 24 hrs at 100%. Should be on mfgs site.
In Pool Math, use the section at the bottom to figure out how many ppm of FC you'd generate at x pounds (converted to ounces).
Depending on your cell rating and the (large) size of your pool, it could be anywhere - my hayward t15 rated for a 40,000 gal pool (producing about 1.5 lbs gas) will produce 7.8 ppm per day in my 23,000 gallon pool, for example.
Once you know what production is possible at 100%/24 hours, you can then dial in your run time/ and OR support it with periodic bleach if it is undersized for your size of pool and desired run time.
With your cya, you want to target 5 ppm if using the swg, so once you get the FC to 5, then run the swg long enough to produce about 2 ppm (or maybe 3) and see if you end up at 5 the next day without adding any bleach.
- this assumes you'd use about 2 ppm per day...you might us more, but use rates with swg are a bit lower than chlorine alone due to the constant chlorination.
In your shoes, I'd be tempted to run the swg all day, eg 12 hours, throughout sunniest periods as this will mean less bleach required if you need it, because the steady state at target makes usage less.
By doing this, you might find that with adequate run time, your cell is fine for maintaining daily FC production, but just not to get UP to a level or not to slam. You can still enjoy the benefits of your investment in this cell by giving it the time it needs to run and using bleach for significant changes or slamming -- that's actually the case with all SWGs...they excel at steady production.
Let us know what pool math says
We'll help get you dialed in now that you've given it a clean start via slam and a fresh cell!
