Thread: Clear, no CC, but heavy chlorine smell
    May 2009
    Peoria, AZ
    13
    I've tested and retested everyday this week, but everytime I go to get a sample I get a whiff of chlorine smell, particularly at the water level. Water is clear, no CC when I test, everything else looks good. Just not sure where the smell is coming from, any ideas?
    FC 4.5
    CC 0
    PH 7.4
    TA 110
    CH 300
    CYA 60
    16000 Gallons Inground \ Pebble Tec \ 1 1/2 HP Whisperflo \ C&C+ 320 \ Pool Thing C390RS SWG \ Polaris ATV
    Re: Clear, no CC, but heavy chlorine smell
    Try raising the FC level a little bit. WIth a CYA level of 60 you normally never want your FC level to go below 5. Try keeping it at 7 and higher for a couple of days and see if that helps.
    May 2009
    Peoria, AZ
    13
    Even though I have a SWG?
    Sorry, I missed the SWG. Ignore my previous answer.
    That is more confusing. Do you have an attached spa?
    May 2009
    Peoria, AZ
    13
    No spa.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I think my pool smells like chlorine too. just like it does when I take the lid off the chlorine jug (just less so). I keep it around 8-10 per the chlorine/cya chart. (70ppm cya)
