Reminder.....
Oct 19, 2015
178
Burleson, Texas
Check those DE filters regardless of what the pressure gauge says!
I was thinking there may be an issue with the guage, how about the flow from the returns, was that reduced?
That actually doesn't look all that bad. Pretty typical for DE. Sounds like your pressure gauge is screwed up. I replaced mine with a liquid filled high precision gauge that reads 0-30psi in 0.5psi increments. Much easier to see pressure fluctuations. Be careful with the high flow manual air relief valve on the top of the filter. They are very easy to crack if you over-tighten them.
I have an oversized QuadDE on my pool and I no longer backwash. I just tear it down and fully clean it every 6 months.
