Ok, my replacement reagents arrived today so I'm back into monitoring mode. Here's what's been transpiring since I ran out of reagent on Tuesday morning.
Tue 5am FC 14 (failed OCLT, loss of 1.5). Added 2 gal 10%
Tue 9pm added 'blind' another 2 gal 10%
Wed 6pm FC 15.5....little lower than calculated. 4 gallons theoretically adds ~25ppm, means I lost over 23ppm over 37 hrs. I was expecting 20ppm loss based on prior days testing (9ppm loss through each of the 2 daylight periods and 2ppm over the 1 night). Added 1 gal 10% at this time.
Wed 8:30pm FC 19....wait a sec. Didn't I just add 6ppm 2.5 hrs ago? Why did I only gain 3.5ppm? Anyway, added an extra gallon 10%. Brushed thoroughly, emptied skimmers (including dead frog) and removed the pool vacuum for the OCLT
Wed 9:30pm FC 22. Ok something's not right. 2 gallons added in the last 3.5 hrs should have added >12ppm but I only gained a little over half that in FC.
So I have something going on with the chlorine addition. I'm waiting 1 hr after addition, with the pump running 24/7, before taking my sample, so I don't think it needs more time for circulation. I went back and looked at my (large and growing) stash of empty liquid chlorine bottles in my garage. Unfortunately I can't remember which bottles I used this evening, but 2 of the bottles had date codes in the 30s and 1 was in the 60s. The remainder were all in the 160s and 170s.
So question - is chlorine 5 months old likely to have degraded to 1/2 strength? It's the Walmart 10% stuff, I assume it's been stored inside, so wondering if it's typical to degrade that much. If so that may have been the source of one of the smaller than expected additions this evening - likely the last one - but not sure about the other as I think I used a newer bottle.
And referencing our discussion earlier. When I started using the new bottle, I could have sworn the drops looked larger than the last one. I read the thread on the wrong nozzle tips being supplied so I checked that and it seems I have the right nozzle. So then I did a comparison step with a 1ml syringe and the results were pretty close - 44 drops with the bottle, 1.8ml x 24 = 43 drops with the syringe. Harder to tell the color change with the syringe, I found. So anyway I think I have confidence that my drop testing is pretty close. Will try the syringe test tomorrow morning as a comparison.
One other change tonight - I hadn't really been brushing the floor of the pool as I have a vacuum, but wondered if there was algae on the floor (I sure can't see it) and it had formed a biofilm, maybe the vacuum wasn't able to disturb it enough to let the chlorine get at it. I thought what the heck and brushed it tonight for the first time.
Anyway onwards and upwards to yet another OCLT. My water is crystal clear in daytime, but with my lights on after dark, I can see floating particles in the water close to the lights. Don't know what it is, maybe it's algae, if so I don't know where it's coming from but it's got to be dead by now, surely. Anyway 8 days now and counting now for what seemed like a very minor algae problem.....
