SWG Saniclear 20 too much FC
shingo
Aug 3, 2015
10
Blainville/QC
I have my saniclear 20 set at 5% currently and my FC vary between 4 and 5.
I have had the water analysed and beside the FC everything is absolutely perfect.
The pool is 13000 gallon.
I feel like even if it says 5% it's generating at 100%
Everytime I check the cell, the voltage and amp indicate it is currently generating.
From my understanding, the % you set the SWG is the % of time of the day it is running.
Any idea?
The pump has variable speed and is running 24/7
What is your CYA level? The CYA level determines how high your FC should be. See this --> [FC/CYA][/FC/CYA]
Why not just turn your pump off? You don't need to run it so long daily....save the electricity :) Or just turn the SWG off when your level is higher than you want.
Are you covering the pool in any way?
I cover the pool at night with a solar blanket and I also have a heater, it get cold at night 50 usually, so I need a both the solar blanket and the heater
