How many GPM for my equipment?
aaronp
Aug 28, 2008
40
I'm trying to determine how long my pump needs to run each day.
Can someone look at my equipment and give me a guess how many GPM my pump is putting out.
I've looked at the pump curves, but don't understand it all.
The pump is about 20 feet from the pool (horizontally) and below the water level. The pump is probably even with about the middle of the deep end.
The pipes that are above ground are 2 inch PVC.
The PCC 2000 floor cleaning system manual says that it needs a minimum of 60 gpm @ 70 TDH
Is that enough info to make an educated guess?
Actually that's what led me to ask the question. I started there.
I know I need one or two turn-overs per day, but I have no idea how long my pump needs to run to turn over once.
If I knew the GPM of my pump and equipment, I could do the simple math and figure it out, but I have no idea how many GPM I am pushing through my pipes.
Is there some way that I can figure this out that I've overlooked?
I was hoping that someone who works with this pool stuff could just say "Oh the challenger 2hp pump puts out about xx gpm, and given your equipment you are probably putting out XX gpm".
