Thread: Intermittent Motor noise
    Rockcrawler's Avatar
    El Paso, Texas
    174
    I replaced the seal between the pump and the motor last year because of a small leak, no problems no rust etc. Now last week the motor has an intermittent humming/grumbling noise (hard to explain) the noise is intermitent, about 15 seconds apart, the noise last about 2 seconds.
    Its a whisperflow pump 2 hp, 4 years old, i have ran it about 6 hrs a day
    I would like to tear it apart and replace what ever is broke, can anyone tell me is there a repair kit I can get that has "everything" I need, I am suspecting some kind of shaft bearing or seal. and where I could get the kit?
    NO water is leaking anywhere from the pump or motor
    Thanks
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Intermittent Motor noise
    The tools are the bigger issue. Do you have a bearing puller? If not, a motor shop would probably do the bearings for you for $100 or less, which about what you'd spend on parts and equipment.
    But that said, it doesn't really sound like a bearing issue to me. Is it any worse when you initially turn the pump on? If you were to put some pressure on it (let's say you put your foot on top of the motor to pin it down a bit) does it change?
    El Paso, Texas
    174
    spishex,
    I went ahead and changed the the shaft seal and the seal on the propeller, got everything back together and the noise is still there but not as much.
    You hit the nail on the head when you said " If you were to put some pressure on it (let's say you put your foot on top of the motor to pin it down a bit) does it change?"
    When I press down on the back off the motor I do not get any noise, I did notice that the pump is not secured to the concrete pad is this the problem? It has been that way since it was installed 4 yrs ago.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Yeah, your problem is vibration. You could use a rubber mat to isolate it from the concrete, or you could get some anchors to bolt it down and stop the vibration.
