Thread: SWG, AGP and CH
    Jun 2008
    NW MO
    185
    SWG, AGP and CH
    I think I understand all the other chemistry components of the water with a SWG, but I am not sure I understand the CH component. Everything I read says that CH and vinyl are not even an issue. Then the recommendations for the SWG is minimum CH of 150. My current CH level is 110. Do I need to bring it up?
    24ft AGP 52in deep ~13,500 gal
    Hayward Sand Filter 250 lbs
    SWG
    1.5 HP pump
    425 gal stand alone QCA Hot Tub 15-20 yrs old
    Re: SWG, AGP and CH
    No, probably not. Low CH levels can sometimes cause foaming. There was a debate a while back about how frequently that is actually a problem. If you have foaming problems that last for more than a week or two, you should raise your CH to at least 150. For most people, CH can be very low without problems in a vinyl pool. I would leave your CH low unless foaming becomes an issue.
    Jun 2008
    NW MO
    185
    Re: SWG, AGP and CH
    Thanks!
    SWG
    1.5 HP pump
