Question. in my case for solar it looks like I have to use my garage and second story roof. My question and problem I think is that the water from the pump will be going up to the second story and then across the roof and to the front of the house and then down a story to the panels on the garage roof and then from there the return would leave the panels and go back up a story to the second story across the roof and back down. I am pretty sure its not wanted to have the solar at a low point but I don't have many options. I would also like to put some panels on the second story as well.. So my questions are how is this best achieved. Basically for the image my pump is at the rear left of the house while the garage is at the front right so complete opposite side. Would I also need a booster pump? I have a 1hp super II hayward. I have an 18x36 and the pump is about 12ft from the pool so I am not sure what head it has currently but I would presume fairly low. The house is about 40ft across.
Thanks for any thoughts.. I had it all planned out but ran into issues with a ton of vents on my roof which is why I have had to use the garage roof.
Thanks
Thanks
