First test with TF100
Jun 17, 2016
22
Ozark, MO
Just competed my first TF100 test.
FC: 6
CC: .5
OTO showed higher than 5
pH: 7.5
Alkalinity: 100-110
CYA: 50
CH: 175
Time to SLAM and clear up that water?
Also wanted to add that the magnetic speedstir is great and worth the money.
Adding signature
That's not bad at all. Fill in the pool details including pump filter in your signature and you should be crystal clear in not that long.
Added two and a half gallons of 10% few hours ago and just tested.
FC: 21
CC: .75
I guess that means there's not much organic left in there and it should clear up shortly?
Not seeing much CC. Doing the overnight loss test in the morning.
Adding signature.....
