Hi Brian, yes his tap water had a high TA and CH and therefore filling the pool with that water was the same as doing a Bicarb startup.
His current pool water is not aggressive enough to be etching or "leaching" calcium out of the plaster. Even if so, the removed calcium would not precipitate out in this manner.
Salt units can have their own isolated chemistry within the cell, and often (but not always) precipitate calcium out of solution even when the CSI is slightly negative.
Your concern regarding calcium chloride addition to the plaster mix can be an issue and a problem in some situations as you suggested, but in this case, with the plaster remaining smooth and dark, I rule out that factor. I think his plaster finish is good.
