Intermatic timer gears not turning
May 19, 2015
145
Burbank, California
The gears through the tiny hole on the base plate don't turn anymore.
I can manually turn the pump on and off using the lever.
I can lift the yellow dial wheel and turn it just fine, and it sits back when I push back. So the spring on it seems fine, and the dial doesn't seem stuck.
I don't have a problem buying a new one. I just want to make sure mine is actually broken. I know very little about these timers.
for the dial to turn, does it have it's own breaker? Is it possible that the wheel/gear isn't getting power? How could i figure this out?
Or is it possible the gears just don't work anymore?
There is a little motor behind the cover that turns the gears. I have had to replace mine after about 4 years. The motor is available as a separate item you can replace or you can just replace the whole unit. Make sure you take lots of pictures as you go.
