Thread: My neighbors swamp.
    oletrout's Avatar
    May 2009
    Hamilton, Ontario
    134
    My neighbors swamp.
    Now that I'm on my way to getting control of my own pool I have convinced my neighbor to do the same so the first step is to get a TF Kit. Ordering it on his behalf today.He will sign up here in the very near future.
    This pool is real dirty and swampy. He was removing the cover yesterday and all the debris accidently got dumped from the cover into the deep end. The pool is 2 yrs old 22 x 50 x 6 rectangular inground with a vinyl lining a main drain ,3 skimmers.
    Equipped with a SWG, Hayward 1hp pump, sand filter Tested his water based on approx. 50,000 gal and the results were basically 0,zip, nada of anything. Didn't test for salt.
    Got the pump started and advised him to start brushing the sides, vacuum/scoop out the bottom **** and start shocking. He put in 30 l of 12% CL yesterday and this AM the FC level was 2.5. Using the PC and a target of 10 I told him to add 23 more L. The CYA/CL chart says 7.6 K of stabilizer. Should that be added right away when the pool is full of algae, foam on the top and debris in the bottom? Should he worry about the rest of the balancing or wait until the algae is cleared up?
    Cheers
    Southern Ontario. Concrete Lazy L shape pool painted in 2005 with 2 part epoxy paint ,42 x 20 , 2.5 ft deep in shallow end , 8 ft in deep end, with what i calculate as an average depth of 6 to 6.5 ft. or approx 38300 Gal. 1HP pump , Hayward sand filter model S-220T rated at 2.64 ft.2 , 52 GPM , Intellichlor IC40 CG
    Re: My neighbors swamp.
    If the CYA level is low, you want to raise it up to between 20 and 30 to fight algae, then take it the rest of the way up after the water clears up.
    Jun 2008
    Ontario Canada
    51
    oletrout-I know this is off topic...but I thought the TF test kits couldn't be shipped to Canada. Or am I incorrect? I clipped this....2. If you live outside the 48 states, [We can ship anywhere in the world except Canada] simply order the kit but stop when you get to the payment section. You are in Hamilton right? I would love to order one and I am in Ontario too.
    FG Leisure Riviera Pool 30X15, 14 300 gallons, Sta-Rite 3/4 HP, Aqua Rite SWG, Kreepy Krawly.
    Beachcomber 360 Hottub, 345 gallons, UV Sanitization System.
    oletrout's Avatar
    May 2009
    Hamilton, Ontario
    134
    Yes that is correct and it's because of distribution agreements with Fisher. Too bad because there's a big difference in price.
    Check your PM's
