Blue but cloudy water
May 30, 2013
8
Omaha/NE
Having trouble figuring out what is happening. Opened pool late this year due to broken pump and waited for part. Been shocking the snot out of it for a week and water is still cloudy. Started the SLAM technique the other day but not seeing any results yet.
26ft Round Above-ground
12000 Gal
SWG
FC- 10+
CC -
Ph- 7.2
TA- 90
TH- 150
CYA - 30
Salt- 3400
Hi, welcome!
First of all what test kit are you using? If you could add that to your signature (thanks for filling out your pool info!) that would be awesome.
Also, if you could put your location in that would be great too.
Great!
Some SLAMS take 2-3 weeks. If you started "the other day" you might just need some time.
How often are you testing and adding FC? Brushing at least once a day? CC would be a good number to track.
Tested FC this am but it seemed to be so high so I didn't do a complete FC/CC test (didn't want to use all my test chemicals) hopefully it will drop a bit during the day that I could track CC tonight
No problem.
You may want to read the SLAM article again Pool School - SLAM - Shock Level And Maintain
Here are some highlights:
You want to bring FC to the SLAM level for your CYA, which is 12 (not 10+ :) )
You want to test more than twice a day and less than once an hour.
CC that's just 5 drops of 003 (? memory) and a few drops of 871?
For your SLAM you should be targeting 12FC. You should be testing and using Pool Math to calculate additions of chlorine. Don't add so much that you end up with chlorine levels that "seemed to be so high so I didn't do a complete FC/CC test". We call this nuclear additions of chlorine. "Nuking" the pool with large amounts of chlorine ends up wasting much of the chlorine as it burns off in the sun quicker and can damage pool parts, especially vinyl pool liners.
Try to stick with calculated doses of chlorine.
This chart is the foundation. I recommend often that people print it out and leave it where they test. I have it taped to the inside cabinet door. It's very important to understand and use Pool School - Chlorine / CYA Chart
Please let us know if the chart doesn't make sense
You should turn your SWG off for the duration of the SLAM also.
UPDATE -
Got home and tested
FC- 4
CC- 1
PH- 7.0
TA- 100
CH- 175
CA- 30
NACL- 3400
12000 Gal round
SWG- Off
Omaha NE
Still cloudy and In the process of SLAMing, should I add more liquid chlorine tonight?
Here is an example of what the water color and cloudiness looks like
ANOTHER UPDATE on my SLAM - Thanks for any advice or encouragement
FC - 10
CC - 1
PH - 7.2
TA - 100
CH - 150
CYA - 40
NACL - 3400
FC was up but my CYA was up from last time probably because I had recently dropped this in the skimmer the other day. So according to POOL SCHOOL i needed to up FC to 16ppm so I did that with LC before coming in for the evening. Still cloudy (i know this wont change instantly) will check results in the AM and update here.
