Thread: pH and robots
    Jun 2008
    France
    18
    pH and robots
    Is it true that pH is important so that automatic robots can climb walls? And IF this is true, why please?! I'm puzzled!
    Inground Gunnite pool 30'x15' - 10mx5m
    22,500 US Gallons / 85 Cubic M.
    Hayward 3/4 hp Triton Sand Filter 220lbs - 100kg
    Auto pH ColorQ Test Kit
    Guest
    Re: pH and robots
    pH is important but not so robots can climb walls!
    Jun 2008
    France
    18
    Re: pH and robots
    Exactly what I thought!! But dealers always ask 'What was the pH?' when I say robot climbs wall once or twice when it's first started, then makes efforts but gets nowhere except the floor!
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: pH and robots
    OK -
    I'm going to be characterized as a nut for this one, and I do ck my pH regularly, but... when I was a teen, I could tell when the pH was high in our pool by the feel of the water. If I rubbed my finger and thumb together on the surface of the water, a higher pH would feel slippery while a normal pH would feel "clean". Also, the pool plaster felt "slippery" to my feet, and I had less traction if I tried to run in the water, with high pH. It was my cue to tell my dad to add acid. Maybe this is what the dealer is suggesting?
    Anyway, I have to think that a robots ability to climb depends on lots of other things besides pH.... seems like a stretch to me.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Re: pH and robots
    I would think the pool store employee was suggesting that an algae build up on the walls might prevent traction. For most APC's a failure to climb indicates a need for tweaking of the APC.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Guest
    Re: pH and robots
    Quote Originally Posted by budster
    Exactly!
