I left my Intermatic Timer open during a rainstorm and now the manual timer on off switch does not work. The GFCI tripped at the breaker so I assume there was a short with the water. Now, The pump is always on and I have to switch the breaker to turn pump off.
I removed the timer dial and sprayed contact cleaner and moved switch back and forth. No luck after doing that. Is the switch repairable or does it need to be replaced?
Thanks
Thanks
