Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: 12% chlorine prices around the country
    Fayetteville, Arkansas
    220
    1 gal is $4.98 and 15 gal carboys are $60.15 + $35 for the refillable container deposit. How does this compare to what some of you are paying?
    20x40 30,000 gal IG Liner, Pentair II Sand
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: 12% chlorine prices around the country
    I bought a 1 gallon jug 12.5% for $2.99 a couple weeks ago.
    220
    Quote Originally Posted by frustratedpoolmom
    I think I'll keep shopping. What is your source?
    11,969
    Local pool store chain, Aqua Pools.
    Sep 2007
    Gloucester County, NJ
    141
    $11.99 for a 5 gal 12.5% returnable container with an $8 deposit per container. I usually pick up 2 or 3 and store in a cool shaded location.
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    220
    Quote Originally Posted by smuggs
    None of the leading pool stores in NW Arkansas sell liquid chlorine -
    The prices in my original post are from a local chemical supply company.
    Apr 2009
    Sarasota Florida
    143
    2.5 gallons 12.5% for $4.76
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    2.5 gallon refills (10.5% around here) are $4.25, up from 2.49 in 2006, but down from 4.50 (leslies was 4.50 but now they're down to 4.25 as is pinch a penny). you can almost always get them buy 2 get 1 free, plus there's the punchcard that gives you one free after 10 refills.
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    My local Leslie's doesn't carry liquid chlorine either. They said its a dangerous chemical. When I mentioned the fact that it was the same as bleach I was told that they are different and that adding bleach from the grocery store is bad for the pool. I just smiled and left it at that.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    wow, in houston? that's surprising. I'm glad everyone carries it here...
    it is a dangerous chemical...but so are lots of things that are readily available (do they sell muriatic acid? take a whiff of that one time...)
    220
    Thanks for all the input on this topic - I'll keep looking and maybe I'll find some reasonable for the season. If not - I'll keep using the 96 ouncers from the store.
    Jul 2007
    Northern NJ
    299
    The cheapest I've found is $3.99/gal for 12.5% and $16.95 for the 5 gal carbouy with a $6 dep. Found at branch brook/namco.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    May 2009
    Rhode Island
    2
    $16.99 for 5 gallon carboy of 12.5% at my local Namco in RI. I'm still trying to figure out if that's cheaper than BJ's wholesale. wally's or Aldi. I guess if I can find 6% bleach for less than $1.70gal I'm good right? My math has always been shoddy
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by BigdaddyBry
    16.99/(5x128x.125) = .212 per oz hypochlorite
    1.70/(128x.06) = .221 per oz so the carboy is cheaper. You'd need to find 6% at under $1.63/gal to be cheaper.
    Where I am, a nearby Lucky grocery store has 2gal 10% for 6.99 (.273/oz hypo).
    The Pool Guys in Saratoga sells a 4-gal case of 12.5% for 16.60 (works out about the same) plus a $5 deposit. They currently have a 2-for-1 deal, which is .138/oz hypo!
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2008
    Southwest New Hampshire
    52
    $2.79/gal for 12.5% at Ocean State Job Lots around New England.
    You can also get Clarifier for $4.99/gal and Algaeside for $3.99/gal for the yet to be enlightened...
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    Aug 2007
    near the swamp
    806
    $3.29gl here, 2.5gl container is $4.10 for the refill, $6.00 deposit for the jug. If you buy in bulk like 20+ gallons, then it's $1.58gl
    All 10.5%.
    Just bought a 5 gal container for $18.99 outside Philadelphia. $7 deposit too. What's that about 3.80 a gallon? I might need to shop around a little bit.
    IG 16,000 Gunite,DE Filter, Heater
    BJC13
    Harleysville, PA
    Mar 2007
    Morris, IL
    477
    I get a 4 gallon case for $9 and change at Great Escape.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Dec 2007
    Central New York
    504
    Utica NY area it is $14.99 for 5 gal of 12.5% It went up a dollar this spring. I see WalMart is selling 10% gals again. I didn't look at the price.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
  20. Back To Top    #20
    Feb 2008
    Milford, CT
    333
    $16.99+$6.00 refundable deposit for 5 gallon carboys of 12.5% at my local Branch Brook/Namco. So $3.40/gallon not including the deposit.
    Never thought about checking Job Lot (which is a lot closer to me, so maybe lugging the bottles around is worth it)
    I dont mind the Namco trips too much though, get away from the family for a while
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
