Thread: Older pool..what to do...
    I am buying a home in Bergen county ,NJ and the house was built in 1965 and the pool a inground vinyl liner was added sometime after thr home was built.So I was told by the now owner.She had a new liner installed with new water last year and a nice new winter cover.Will there be other issues I should look for being this pool is very old? I do not know the construction of this pool or if they were built different back then.Is this a pandoras box and I should run fast or move forward?
    20K gal.
    Hayward S-244T sand filter
    IG vinyl
    Re: Older pool..what to do...
    It would be a good idea to get a professional out to inspect everything, especially the equipment pad. Many pools from that era are still fine, but they need to have had proper maticance and equipment upgrades along the way.
    Did they use steel walls and cement bottoms back the o r something else?
    Thanks
    20K gal.
    IG vinyl
    Oct 2007
    Philadelphia, PA
    86
    For what it's worth, I bought a house in the Philly area with a vinyl pool built in 1967.
    The pool has had the liner replaced several times and it looks like the equipment was replaced about 15 years ago. The steel walls look fine -- or at least the small part of them I've been able to see. The bottom is probably "poolcrete" and seems fine except for one divot in the deep end.
    I would second the recommendation for an inspection. There were very different safety standards in place then. You may want to do some upgrades to make the pool more in line with current codes. It's probably impractical to bring the pool completely up to current standards, but you should have the inspector look carefully at the bonding, fence and gates.
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    Thanks ..any information is greatly appreciated and needed.
    20K gal.
    IG vinyl
