Cell & Flow Switch Location
May 16, 2014
7
Atlanta, GA
CircuPool RJ-60 Plus
I'm in the process of installing an Aqua Rite 15 chlorine generator and need some advice on where to locate the cell and flow-switch. I'm thinking about installing the cell on the vertical return after the pump and filter. I'm not sure where I should install the flow-switch. Can the flow-switch be installed on a vertical pipe? I'm willing to re-plumb to better the setup if needed. Any advice would be appreciated.
Thank you!
