Thread: How long to wait until I test
    May 2009
    Kentucky
    9
    Ok I got my PH up to 7.6 and my TA is a little high at 100, but I just added my first round of bleach to shock the pool. My question is how long should I wait to test to see if I'm at the correct shock level for my FC?
    Location = Central Kentucky
    Pool Size = 18x36 - 8ft deep end
    Pool Type= Inground Vinyl
    Filter = Hayward PRO Series Sand Filter
    Pump = Hayward Super Pump 1.5 HP
    Test Kit = TF-100
    Apr 2009
    Sarasota Florida
    143
    Re: How long to wait until I test
    Quote Originally Posted by kediedri
    half hour with pump running
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    It's always!! best to, please, post full test results when asking a water chemistry question In this case, we may be able to tell you if you actually need a lower TA 8)
    GLAD you're here Hope you have a trouble free pool season
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    Hi kediedri and welcome
    Ditto on the 30 mins. w/pump running.
    Also, your TA of 100 is fine. No need to lower it unless your pH is constantly rising.
    You're done SLAMing when:
