Did you test CYA in the bright sunlight, back to the sun with the vial at belt buckle level? This test is very sensitive. I'm asking because it is a little cloudy this AM and not ideal for testing CYA.
Plug your numbers into Pool Math. According to your CYA, your SLAM FC should be 16. Pool Math will tell you how much bleach to add to reach FC=16. If you have questions figuring out the amount, just ask. Test every couple of hours, add bleach as needed to keep FC=16. As you are able to hold your FC level, you can test and adjust less frequently. At this point of the SLAM, just test FC and CC.
CH isn't as important as you have a vinyl liner.
