Update: I came home and before I turned on the SWG, I decided to unplug and replug in the cell to the panel. Then I turned on the SWG, the Generating led lit up, and then I waited. Checked it again only this time the Check Salt and Check Cell led's were not lit, and the salt level which is factory set at 2600 had moved up to 2700. Yay!! So looks like all it needed was a "reboot" of the cell.
I'm just not sure what to set the output dial to. I am going to take a chlorine reading in about an hour and I guess that will determine where to set the output dial?
