Results 1 to 10 of 10
Thread: Does this sound right?
    Jun 2007
    Spring Hill, FL
    29
    14K IG Diamond Brite finish
    based on my #'s I am going to add....
    4# Baking Soda
    2 Gal Cholrine(sod Hypo 10.5%)
    Pinch A Penny Test
    TC=0
    FC=0
    pH=7.4
    TA=65ppm
    CH=350ppm
    Stabilzer=100ppm (is this cya?)
    Thanks
    14K Gallon IG Diamond Brite Finish
    24SF DE Filter
    Arizona
    925
    What levels are you trying to bring your chlorine and alk up to?
    Yes, stabilizer is CYA.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jun 2007
    Spring Hill, FL
    29
    Chlorine 2-4 ppm
    TA 100ppm
    24SF DE Filter
    Arizona
    925
    You would only need about 1/2 gallon of 10.5% chorine to bring your pool to 4
    and about 92 oz of baking soda to raise your TA from 65 to 100.
    Buggs
    Jun 2007
    Spring Hill, FL
    29
    Thanks
    24SF DE Filter
    Jun 2007
    Spring Hill, FL
    29
    ok just for ****s and giggles I took another sample to the same chain...
    TC and FC still=0
    pH=7.6
    TA=120ppm ( previous 65 ppm)
    ch=325
    cya=100ppm
    TDS=1500 ppm(previously not tested)
    confuesed???? me too.
    what now?
    Gary
    24SF DE Filter
    Jun 2007
    Spring Hill, FL
    29
    BTW pool is very clean and is great
    24SF DE Filter
    Arizona
    925
    This is a good reason to purchase a good test kit and learn to do your own testing.
    Buggs
    Jun 2007
    Spring Hill, FL
    29
    Trying to add a pic
    24SF DE Filter
    Jun 2007
    Spring Hill, FL
    29
    second try
    not adding attachment?
    24SF DE Filter
