110v / 220v valve
What percentage of chlorine are you looking to control?
Are you sure that you a need 110v/220v actuator?
Do you want varied control or just on/off?
Do you have an air supply available or does it need to be all electric?
I would prefer it capable of handling 12.5% chlorine.
It does not have to be. A 12v with converter would be fine I guess.
I only need on/off. I am trying to pre plan to use the free Dosatron that I picked up last night.
I would rather it be electric. I have a compressor but its really too far away.
I plan to put a "loop" in my existing plumbing to attach the Dosatron. I will have a manual shut off valve so I can adjust the amount of pressure the Dosatron receives but I was thinking this morning that it would be nice to have a valve that is typically closed until it receives a current and opens. That way I could have the Dosatron only being used when I need it versus working the entire time the pool pump is running. This would allow me to use it like a stenner pump setup instead of the constant flow. I really dont think I can lower the constant flow enough to allow it to run the entire time the pool pump is running. Hope that makes since.... I am also open to suggestions.
