Thread: no CYA, is that OK?
    Mar 2008
    Delaware
    40
    no CYA, is that OK?
    had Leslie's test my pool water last night while i bought a new pool cleaner. i'm BBB, and test at home, except for CYA.
    they said i have NO CYA. I expected that, since i don't use pucks.
    but now i'm left wondering, do i need a little CYA? or is it pointless to have any at all?
    thanks
    Thank you in advance for your help.
    Noctiss
    Re: no CYA, is that OK?
    In an outdoor pool it is important to have some CYA. With CYA at zero you will lose all of your chlorine to sunlight each day. It is important to maintain some FC level all the time, which can't be done without CYA.
    You should add CYA/stabilizer/conditioner to raise your CYA level up to around 30 to 50.
    Mar 2008
    Delaware
    40
    thank you for the quick info. i will do that.
    is there one type of product that is better than another, or all they all the same?
    do i add it to a return or to a skimmer?
    Noctiss
    Jan 2009
    Cupertino, CA
    1,966
    "Conditioner" or "stabilizer" it's all the same stuff. The only difference seems to be granulated versus liquid. The granulated stuff can take a long time (a week?) to dissolve; most people seem to dump it into a sock and put the sock in the skimmer basket or hang it in front of a return. Liquid is more expensive but obviously is pre-dissolved so it takes effect right away.
    --paulr
    BBB "Intermediate Swimmer"
