Thread: Total Alkalinity and Free Chlorine
    Aug 2008
    Hebron, CT
    79
    I have a SWG and a vinyl pool. I see that TFP suggests TA to be on the low side of 60-80 and Free Chlorine to be 3-5. My concern is my SWG manual suggests a range of 110 to 180 depending on the saturation index for TA. They also suggest Free Chlorine of 1 to 3 ppm. Which should I follow? Thanks!
    22,500 gal Lagoon shaped inground pool, vinyl liner, Hayward 4800 DE Filter, Hayward 1.5 HP super pump, Aqua Heat Pump, Nexus Pure SWG, Dolphin Triton PS, Hebron, CT
    Guest
    Re: Total Alkalinity and Free Chlorine
    They are basing their recommendation on standard industry recommendations that have been found to be 'not quite right'. In fact. their TA recommendation is not in line with the APSP suggested levels as taught in CPO (certified pool operator) courses for comercial pools.
    With an unstabilized chlorine source or SWG the recommended level is 80-100 ppm. (for stabilized chlorine, bromine, chloirne gas, and MPS then 100-120 is recommended because these are all acidic).. we have tweaked it down a bit because it helps maintain better pH staibilty. In fact, Goldline (one of the big US manufacturers of SWGs and a part of Hayward) techs are now recommending TA at abut 70 ppm for the same reason.
    These two theads might help explain why:
    ta-what-is-it-really-t4979.html
    water-balance-tips-for-a-swg-t3663.html
    FC recommendations are correct for a pool with NO CYA but once CYA is introduced that changes. The industry is JUST beginning to take this into account but the large trichlor manufacturers do not want this information widely known since it will hurt their business. However things that are firmly entrenched in the industry are hard to change. A prime example is the myth that 'slugging acid will lower TA" even though it s been debunked by scientific research!
    Jun 2007
    NC
    255
    Quote Originally Posted by Reibeling
    Welcome to TFP!
    It'll help if you read this post http://www.troublefreepool.com/what-...ns-t10341.html and add the information to your question.
    There are many here with LOTS of experience that will be glad to help with your questions. There are different recommended levels for each manufacturer; some good and some "not-so-good".
    Thanks!
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    WNY
    35
    I have found that keeping my TA around 90 keeps the pH from drifting up.
    23000 gal. 18 x 36 IG vinyl
    Jacuzzi Magnum Force 1.5 hp. pump
    Jacuzzi CFR 100 cartridge filter
    AutoPilot Digital 220 SWG
    LaarsLite 250 gas heater
