Buying Diatomaceous Earth, Muriatic Acid, and Calcium Chloride
Apr 29, 2016
91
Houston, TX
I found a 50lb bag of DE for $50 online from diatomaceousearth.com but it is listed as food grade. Is that a good price and is food grade ok for the pool filter?
Next, I can order a 50lb bag of calcium chloride marketed as Snow Joe Ice Melt from Home Depot for $15, but it looks like the crystals are quite large. Maybe the image on the Home Depot website is throwing me off, but they look like the size of chocolate chips. Normal?
Finally, Home Depot sells 2 gals muriatic acid 31.45% for $11. Is that a good deal?
Food grade will not work for the pool. You need the type made specifically for pools, usually listed as "filter aid". I'm not sure about the salt, thinking ice melt is different, but possibly the kind for water softening will work. (Not positive on that though, someone with an SWG can probably better answer that.)
Do you know what makes the D.E. different in food grade vs the type one would use in a pool filter? Is there some kind of additive in it?
Sent from my SCH-I545 using Tapatalk
Pool DE is heat treated so that the particles are in a crystalline form that filters are designed for.
50lbs is a lot anyway. I know we razz on pool stores here, but they are usually the best place to get it.
It's some kind of heat treatment. Garden DE comes in nice small bags but it isn't suitable. You can substitute cellulose filter media for DE. It's a lot lighter and comes in smaller bags. Not sure if it's much cheaper, though.
The acid from HD is fine to use, and the price doesn't seem outrageous. You won't be buying enough of that to make it worthwhile to spend a lot of time hunting for the best price.
Check the ingredients on that ice melt. A lot of it also has salt or Magnesium salts in it.
Thanks for the replies. I thought I read somewhere on this site that cyanuric acid is the only thing we need to go to pool stores to buy. So where should we go to buy the correct D.E.?
Pool stores aren't inherently bad. We just find that the majority of recommended chemicals can be found at grocery/hardware/big box stores for cheaper. Your mileage may vary depending on what is local. I get everything from a combination of the Pool Store, Walmart, and Home Depot. This year I ordered CYA from amazon.
Most of the hate for pool stores here is due to the terrible chemistry advice that they use to push sales of expensive and useless "dump & pray" type products.
The HD Muriatic Acid is the same price as around here, and is as good a price as I've found. Just check the label -- many of the stores here have 14% MA for $10 in similar boxes (labeled "pool", while the 31.45% is labeled "contractor strength" but also lists pool pH as a use), which is obviously not as good of a deal. Often the boxes are mixed in the same stack, and one HD here only carries the 14%. Do note that some people prefer to pay a bit more for the lower strength because it fumes a lot less so is easier to handle.
As others have mentioned, pool DE is treated very different from the food-grade DE used around plants etc. You can't use the food grade in the pool, and can't use the pool stuff in the garden.
I just bought a 25lb box of DE at Home Depot over the weekend for $20.00. Seemed to be a good price.
Just as you were writing this post, I found the exact same product at Home Depot online. It shows up in the Home Depot website as "DE Filter Aid" so my initial searches spelling out "diatomaceous earth" didn't bring it up.
I encourage every new member to take a step back when it comes to buying chemistry. You must be careful not to be penny-wise and pound-foolish.
Saving nickels and often even dollars is important but, BY FAR, the most important thing is to understand why you are using these chemicals and what the consequence to your pool will be.
One careless mistake in measuring, testing, dosing, etc. may wipe out a years worth of saving for the cheapest price.
So, make your testing very precise.
Make your dosing amounts very precise
Know the outcome of the dosage before you ever put it in the pool.
Understand why you are making these changes.
I agree that cheaper is not always better. I bought a few gallons of acid at HD for about $6.00 cheaper than Leslie's and later I found it was half the strength which meant I needed to use twice as much which cost me more in the end. Back to the good stuff :).
Hope the DE I bought does not come back to haunt me.
