Results 1 to 7 of 7
Thread: How do I run SWG with an Intelliflo VF?
    Mar 2009
    Glendora, California
    169
    I purchased new equipment but am considering returning the 3/4 HP RS Hayward for an Intelliflo VF. I also purchased a Hayward Swim Pure Plus which I will keep. I would not want to buy the control panel for the Intellilflo. Is there a way to turn on the SWG when the pump turns on without buying the control panel
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: How do I run SWG with an Intelliflo VF?
    This was discussed in this thread. Basically your options are to just depend on the flow detection of the SWG and leave powered on all the time or run it through a current-sensing relay that is connected to the Intelliflo's wiring.
    Jul 2007
    Sahuarita, AZ
    278
    In my system (and I think in most systems) the SWCG is wired to the same power relay that the pump is on. Thus the pump and SWCG turn on and off at the same time.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by EskimoPie
    The problem with the intelliflo is that it requires power 24/7 whether or not it's running, so with that setup you could have power to the SWG but no flow, which is fine if the flow switch is working properly.
    Mar 2009
    169
    That's what I needed to know. Thanks a bunch!!
    Solaxx Ph-Tek
    Mar 2009
    169
    One more thought on this. Can I wire the VF per insctructions, program start/stop times then put my SWG on a timer that turns on 1 hour after the pump does and turns off on hour before the pump? I'm trying not to depend just on the flow sensor. Are there problems I am not aware of if it's done this way?
    Solaxx Ph-Tek
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    As long as the timer keeps time properly and there are no power outages that should work fine.
