Thread: Leak at the 3-way valve
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    So, fired the pump up today after the electrician came and rewired. Discovered that the 3way valve is leaking where the pipe is glued in. It had a minor drip last year that I wasn't worried about, but this year its worse, constant leak.
    Taking it apart won't work, as its the glued joint on solid abs pipe. Can I epoxy the connection?
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Leak at the 3-way valve
    You can epoxy, but that probably won't last long. You can permanently re-plumb it using a socket saver or a pipe extender.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Thanks Spishex! I didn't know that existed. Its a tight fit, but I may be able to get the socket saver in there.
