Results 1 to 9 of 9
Thread: Solar-Blanket Repair ?
    Canada
    29
    I have an older solar-blanket and because the pool is a "lazy L " shape, the blanket takes quite a beating ( as I have to partially fold it in order to make the turn and get it on the reel)
    The seams are starting to tear-apart. Is there a paticular repair material that I should use to fix the rips?
    ( or is duct tape the way to go?)
    I'd like to at least get through this year without buying a new solar cover
    Canada
    29
    bump
    don't think anyone saw this question
    Iowa
    38
    Good question....I have the same problem with mine and was just about to post the same question.
    Canada
    29
    bump
    still no answer yet
    Arizona
    925
    Well, "The Handyman's Secret Weapon", aka duct tape, does come in an array of nice decorative colors, these days.
    I don't know the real answer to your question, but boy, I've used that stuff for a myriad of repair jobs that held up through rain, so perhaps it would work for your cover.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jun 2007
    Edmonton, Alberta Canada
    22
    It might take some time, but I would sew it with lite duty fishing line. Then you wouldn't see the patch job. Just my .02 8)
    Alex
    Re: Solar-Blanket Repair ?
    I have the same problem with my 24' round solar blanket. It's starting to rip at the seams. I have seen solar blanket tape online for $6, but that looks like it is more for patching holes than fixing ripped seams. Unless anyone else has any suggestions, I'm going to go with the medium duty tarp repair tape I found online for $18 for a 3" wide x 60' long roll.
    20k inground fiberglass
    sand filter
    k-2006 test kit
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Gorilla tape.
    We cut our solar cover to make it easier to put on and take off. We taped the seam ends and edges with Gorilla tape. It has withstood water, sun, and frequent handling and is still stuck on as tightly as ever.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Jun 2017
    Phillipsburg, NJ
    1
    Quote Originally Posted by RavenNS View Post
    Try the clear gorilla tape. It appears that it meets all of the requirements for doing a repairs such as this.
