Thread: Pentair Sand Dollar Filter
    I currently have this filter with 1 1/2 pipe coming out of it. I'm in the process of installing a Salt Chlorinator which is 2"....Is it possible to run 2" pipe out of the filter valve, run it to the T-Cell and Flow meter, then reduce it down to 1 1/2" to match up with the rest of my plumbing....
    Thanks
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Pentair Sand Dollar Filter
    The simplest solution would be to put 2" > 1.5" bushings in the unions for the cell. If you decide to do 2" from the filter you'll need to go 1.5" Male Adapter, about 4" of 1.5" pipe into a 2" > 1.5" bushing, into a 2" coupling. Always nice to add 2" pipe where you can but the Sand Dollar Valve restricts you to 1.5" GPM rates anyway.
    I asked them to make a 2" valve for the SD-80. They said they were working on it. 2 years ago...
    Thanks....If you look at the outlet on the valve, currently there is a 1.5" male pvc threaded fitting in there. It appears that it can accept a 2" female PVC threaded fitting, but not sure if thats the case or not...The threads look a little coarse...
    Thanks
    Salt Water
    Sand Filter
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Those outside threads are for a union fitting.
    OK Thanks....I'll stick to 1.5" then...
    Salt Water
    Sand Filter
