Thread: Kool deck is starting to peel up :( What can I do??
    I have a little spot of Kool type deck that is starting to peel up and wonder if there's anyway that I can repair this myself. I'd like to say I knew what the underlying cause was/is but I don't-it's hot, same as it's been every summer here in AZ, no excess water, no huge impacts that I'm aware of so I'm stumped but I would like to fix this before it really gets bad. And I do not use the Weber in this area for grilling.
    Thanks in advance for any advice on how I can repair this!
    Tracy
    Phoenix, AZ
    12,500 gallon vinyl AGP
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Kool deck is starting to peel up :( What can I do??
    The link below is for a repair kit. If you are going to fix it check the spot to make sure it is adhered around the edges. You wouldn't want to repair it and have it chip up around the fix.
    http://www.mortex.com/products/kxrk.html
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
