Green pool need help with SLAM
So, our pool has a funky smell and has a green tint.
PH 8.2
CH 0
CC 0
TA 80
CA 250
CYA 25
Temp 75
Salt ? Easy touch remote and main box reads 0 ppm with COM LINK ERROR. Salt cell is all green lights.
We've only had to SLAM our pool once so I cant remember if I should fix the PH, CYA or CH first.
I would lower pH right away to 7.2. Also get a water sample and verify CYA one more time. If you are sure it's below 30, add just a little required stabilizer to ensure you are at 30, then increase FC to 12. Sun's getting hotter and you'll need that CYA protection. Just leave the SWG off for now as to not mess with your FC SLAM calculations, and you can fix it later. Regular HEB (Bravo) or Wal-Mart (Great Value) bleach will serve you well for the SLAM. :)
