Pump Leaking between case and Motor mount
I would suggest turning off the pump ;)
Hard to tell anything from that picture.
I think you need to start pulling it apart and find where the leak is coming from. That seems too extreme to be a shaft seal unless it broke.
Hopefully, the pump has not cracked.
Looks like you blew out the O-ring sealing the front and rear shells of the pump housing. Most likely due to the stripped screw. If its a machine screw you might be out of luck. If its a coarse threaded screw you may, and I stress may, get lucky with a slightly larger diameter screw.
You might be able to have a thread insert installed. I'm not sure if that is doable, but it's worth a try. And since your pump housing is a gonner anyway, you could experiment. Larger hole, new threads if there is room.
It's looking grim.
