Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Which Aquachek Strip to Believe??
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I bought two bottles of Aquachek salt test strips this year because I thought the first bottle might be leading me astray. The first bottle I bought has an expiration date of 01/2010, and the second has an expiration date of 01/2011. I just tested the same sample of water leaving each strip in for 30 minutes, and here's the results:
    exp date 01/2010 : between 3080 and 3330 ppm
    exp date 01/2011 : 2670 ppm.
    The reason I thought the first bottle was leading me astray was because the first test I did, the level was 2440. I added roughly 50 - 60 lbs of salt, and it didn't move. I bought the other bottle of strips, and my initial reading was 2460. I added another 40 lbs of salt, and now I get the readings I posted above.
    My initial inclination is to believe the newer strips over the older ones, but when I run the numbers through the pool calc, it looks like the older strips match up more closely for the amount of salt that was added.
    Methinks I might take a sample to the local pool store and see what they say, just for comparison.
    Thoughts??
    Mike
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Re: Which Aquachek Strip to Believe??
    Could you please check something for me? I have a theory about how to tell good salt test strips apart from bad salt test strips, but I don't have any bad salt test strips to compare to.
    If you could, take a close look at the horizontal yellow stripe at the top of the reading area. This is the stripe that turns brown to indicate that the test is complete. Compare the color/shade of yellow between unused strips from each bottle. I am wondering if the yellow stripes on the bad bottle have already turned brown, or discolored in some other way. In theory, a strip that has a nice clear yellow stripe should be good and a bad one should have a brown or discolored stripe.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Jason,
    I just checked, and both look yellow, and identical. Neither one appears to be darker or discolored.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Oh well, it was worth a try.
    Feb 2008
    Denton, TX
    5,061
    Might be worth a shot to call Hach and speak with a tech about that. 574-262-2060. It may be a quality control thing.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    True. I'll try to take a sample of water to the local pool store tomorrow and see what they say it is. I was thinking about trying to do some baseline testing here, but if 25lb of salt/1000 gallons = 3000 ppm, then scaled down, that would be .025 lb (55 g) of salt per gallon. I don't have a scale that measures that precisely.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by 257WbyMag
    Thanks. I might just do that.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    I am having the same dilemma. I have strips that expire in June of this year that read 3110ppm and I was getting a "low salt"code. The water didn't taste salty so I got new strips that expire in 2011 that give me a result of 2280. I am trusting the new ones. The yellow stip on the old ones appear to be tinted brown in direct sunlight but appear the same under indoor lights.
    Just my .02.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Jun 2007
    Arlington, VA
    29
    Could you please check something for me? I have a theory about how to tell good salt test strips apart from bad salt test strips, but I don't have any bad salt test strips to compare to. . . . I am wondering if the yellow stripes on the bad bottle have already turned brown, or discolored in some other way. In theory, a strip that has a nice clear yellow stripe should be good and a bad one should have a brown or discolored stripe.
    That was certainly the case earlier this year with almost-but-not-quite-expired test strips that led me astray earlier this season. The yellow band wasn't as dark as it gets in the testing process, but it was definitely discolored. A good warning sign.
    ____________
    34,000 gallon pool with charcoal Marquis aggregate finish
    Jandy stealth pump, cartridge filter and Aquapure SWG
    Solar heating with Goldline controller
    Polaris 380 Blackmax
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Hmmmm. Mike, I just posted above about my testing the AquaChek strips against the Taylor K-1766 drop test. My particular strips read within 5% of the Taylor drop test. They expire August 2010. Might be worth it to get a Taylor kit just to compare which strips may be "bad" or reading incorrectly for the future. I got this "backup comparison" kit just because I don't want to oversalt and have to drain! HTH... Just my .02!
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I read your other thread and thought the same thing.."I need a K-1766 kit". Where did you get yours at, if I may ask?
    Intex 8110 SWCG
    "Fear the Schnauz!"
    billybrobob's Avatar
    Apr 2008
    NW Florida
    31
    Spend $10 for a third test. You will have two good ones (probably), and you can't put a price on a good nights sleep.
    40,000 gal pool, Goldline SWG, 1.5 hp pump, sand filter, plaster w/epoxy paint.
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Mike, since Duraleigh doesn't sell them, or anyone local, I checked Taylor's website...they sell them, but their credit card ordering was temporarily disabled. I went to PoolPlaza and ordered it. $23 plus shipping. I know it's just one more way to spend $$, but I feel better being able to compare this test with my test strips. I know I'd spend money if I had to drain and refill, plus the agony of it! HTH!
    Taylor K-1766: http://www.poolplaza.com/merchant.mv?Sc ... gory_Code=
    Pisces Pool Build
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Too funny...yesterday I checked around online, and found the same thing you did - couldn't order directly from Taylor because their credit card ordering script was down, and Poolplaza was my next choice, so I ordered from poolplaza...and then I log in today and find your post.. Soon as I get my kit, I'll update this post as to which bottle was fibbing to me.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    LOL!! Hopefully you'll get the kit fast, but it won't be "Duraleigh" fast. I swear, sometimes I think he flies down here from NC and put the stuff in my mailbox himself. Hey, I'm anxious to hear which strips were off....I'll be looking for your results. Happy testing!
    Pisces Pool Build
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Got my new kit today, annnd (drum roll please)......it measured 2600 ppm. So it looks like the newer strips are good (exp 01/2011), and the older strips are kaput (exp 01/2010). Of course, now I've got the K-1766, and don't really need test strips anymore. Also looks like I need to bring my level up another 400 ppm, too.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Guest
    Quote Originally Posted by MikeInTN
    ROFLMAO! Don't be too sure!
    Just wait until you get indelible black stains on your fingers or nails and get permanent stains inside your testing vial! (Hint: stuff a wad of tissue or toilet paper in the vial and wipe it out after each test to get the precipitated silver chloride out! It takes a bit of scrubbing, btw.)
    Have fun and let us know when you decide to go back to the strips!
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Quote Originally Posted by waterbear
    No kidding, right Waterbear?!! I'm just using that stuff *very carefully with rubber gloves on* to double check things occasionally!! Mike...so glad you were able to tell which batch was bad!
    Pisces Pool Build
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Evan, nitrile gloves from Sam's means never having to wonder where the stains came from on your hands. I always have at least one open box in the garage for when I work on my automobiles and for weeding flowerbeds, and since I've been duly warned about the silver nitrate, I won't use the K-1766 unless I do have gloves on. I do appreciate the tip about getting the precipitate out of the tube, when that becomes necessary.
    Pisces, thanks for the kudos. It's kind of irritating when two bottles of strips give such different results and you don't know which one's fibbing to you (especially when both were sold to me as "new" this year).
    Intex 8110 SWCG
    "Fear the Schnauz!"
  20. Back To Top    #20
    Guest
    Real men don't wear glove! We don't need no steenkin' gloves!
    After every test, actually!
