Thread: SAM light fixture
    SAM light fixture
    SAM light fixture not coming on. Is this a simple matter of replacing a bulb? Any suggestions?
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: SAM light fixture
    I'd check the electrical connections first, the SAMs have 2 bulbs and it seems unlikely that both would have blown at the same time ... unless there was some sort of power surge.
    If the electrical is all good, you can pull the light up to the deck, disassemble it and check the bulbs - Ace Hardware often has replacement bulbs for 1/2 the price of OEM bulbs - bring one with you and match it up
    I hope this has been "enlightening"
    Luv& Luk
    -Ted
    Quote Originally Posted by waste
    Thanks a lot. I suppose I need to turn off all power to check the connections. Right?
    14,500 gal pool
    Inground
    Water Fall
    Mar 2007
    4,160
    It's best to kill the breaker when playing with the lights, pump, etc, anything electrical
    However, if you're using a voltmeter to test for power, the breaker and switch has to be on.
    Luv& Luk
    -Ted
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Lamp, 75 watt, Eyc, MR-16, Sa 150 watt, 2 req. That's the bulb(s) for the SAm.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
