Am I correct?
Am I correct in assuming that it takes just as much chlorine to to maintain a FC level of 8 as it does to maintain a FC level of 4? :confused:
As long as you maintain the same FC/CYA ratio, then your daily loss to UV light (the largest contributor to FC loss) should be roughly the same. Algae or excessive CCs will increase the FC loss rate. The FC loss rate to UV light is based on the amount of hypochlorite ion (OCL-) in the water and the concentration of hypochlorite is proportional to the FC/CYA ratio.
