Missing Part
May 12, 2009
107
Just topped pool up for new season hooked everything up and the cap that goes on the bottom of my sand filter is missing....it is a threaded cap...anyone know what I can do to replace it...Doughboy above ground pool with doughboy filter and pump..
Without the threaded cap water keeps coming out filter.....
can you explain what they all means... :)
Also I can't run my pump with out it b/c it leaks out the bottom...it is the spigot looking shaft at very bottom of sand filter...How can I pump and circulate water until I get part?
I guess I am not sure what filter you have and what part is missing. Picture?
If you do not have a multi-valve that has a recirculate option, then you can not run the pump until the filter is plugged.
