- Jun 12, 2011
- 3,762
- Plaster
- Pureline Crystal Pure 60,000
Each cell T-3, T-9, T-15 will produce a specific quantity of chlorine before it is depleted. Somewhere there is a chart that tells how many pounds of chlorine each one will produce over it's lifespan, as well as how much it can produce in a 24 period at a 100% setting. Since the output control setting simply cycles the power to the cell on and off, I don't see how the cell would be used up when it just setting there turned off. I suppose you could have your water chemistry so far off that it might damage it, but other than that, it shouldn't matter the size of the pool it's supplying, it will still put out X amount of total chlorine over the lifespan.
UPDATE: I found the chart, so you can compare the cost vs total lifetime output of each size cell. Figure the relative value for yourself.
T-3 = 210 pounds
T-9 = 385 pounds
T-15= 580 pounds
**Equivalent pounds of Trichlor produced over the lifetime of the cell with properly maintained cell and water chemistry.
T-3 = 210 pounds
T-9 = 385 pounds
T-15= 580 pounds
