Thread: CYA help!
    CYA help!
    I kind of need this answer quick! I just added the CYA powder (I know, it's 11:00 at night...) I've got the filter on, but is it ok for that powder to sit on the bottom of the pool? I have a pebble tec finish. I brushed it around a little, but it's not dissolved yet.
    (I guess i can stay up and babysit the pool if i have to!!)
    Sunny SW Florida! Uncaged Free-form IG pool, Pebble-tec finish, 20,000 gallons?? (Beach entry/tanning ledge is 9' x 9'; it's free form 37' x 19'. Depth 3 feet to max 5.5 feet. There's also an attached spa with spillover: 6 foot radius. Anything else?)
    Prologic computerized thingie with SWG; 1.5 hp Hayward II Super pump, cartridge (i think) filter. (Hubby contracted the whole thing...so I don't have a detailed list on what we've got!)
    Re: CYA help!
    It would be a really good idea to vacuum it up with a manual vacuum or a suction side cleaner, or brush it all into a main drain, so it goes into the filter. CYA is acidic and could cause plaster damage. The risk isn't huge, but why run any risk of damaging your fancy PebbleTec?
    Re: CYA help!
    Thanks, JasonLion! Just what I wanted to hear. I've got the Baracuda running in there, and I'll go out now and sweep it into the drain. I was afraid maybe sucking it up would lessen it's effectiveness, though I realize that's why you don't backwash the filter for a while after adding CYA.
    Thank you...again!!
    off to sweep...
    Kathy
