Is it okay to pull off or unscrew laterals? It would make getting standpipe unstuck much easier.
https://onedrive.live.com/redir?res...authkey=!ANrvErdf46v8VN0&v=3&ithint=photo,jpg
do those clips do anything good for me? I'm guessing that pvc is just stuck in black.. But it seems in there good, any suggestions on how to seperate them without risking laterals slamming down into sand? ( if laterals can't / shouldn't be undone.
Found the Pentair Sand Dollar manual online:
http://www.pentairpool.com/pdfs/SandDollar.CrystalFloIITopMountOM.pdf
After putting in new sand and buttoning it all up it says to:
while still off, select backwash, open manual air bleeder, let fill and when steady flow of water out manual air bleeder occurs to close it and continue to let it backwash "at least 2 minutes" (should I do 3 or 5?), turn off, rinse, on, "at least 2 minutes" (longer?), off, set to filter and open manual air bleeder, on. The most important part is the rinse as that gets all of the not so good stuff up and out.
So yeah, I need to add about 3 hours of water tomorrow before I can do that and still be above the skimmer line. If all that goes well, it is chemical warfare time! MA, Cl, and CYA! Not to mention hundreds and hundreds of calories of brushing! Good times. Only kink is that tomorrow I am volunteering at a "Fun Run" so that will interrupt things somewhat. Also installed new psi gauge and read threads debating removing the plastic nib to vent internal pressure....but couldn't figure out what the consensus was on that. To anyone nervous about installing it, don't be. Spend the $15, grab a wrench that fits, unscrew the old one, wrap Teflon tape around the threads 3 times so that the direction you will be turning it will not try to lift off the tape, screw it in easily so as not to cross thread. YAY! PSI gauge is replaced and you know when to backwash/yank and hose the cartridge.
Outstanding Questions:
1) any modifications/suggestions to above new sand turn on procedures? Do as the manual says. The most important part is the rinse as that gets all of the not so good stuff up and out.
2) it looks like it takes 8 hours to turnover my water once - so how long do I need to wait to retest ph after adding MA? Should I take samples from each end of the pool (skimmer/return side and other end) and just use an average after 30 mins?You only need to wait about 15 mins. Just time enough to brush your pool to help mix it in. No need to get water from different parts of the pool.
3) since I've siphon vac from the bottom and filled about 2.5 feet of water - the pool no longer smells like sewage and viability is greatly improved! I'm now thinking the ammonia battle will not be so bad, but will still test after 10 mins to see if any Cl survived the first shock level dose (which with zero cya is 2-5 ppm correct?) I would shoot for 5 so you will know for sure if there is a ammonia battle needed.
4) Continue 10 min testing and shocking until it holds 50% shock level FC then add CYA and test/add every 30 mins? Correct. ONCE you start seeing your FC hold you can back up the testing times to 1 hour, 2 hours, ect as you see the FC holding longer and longer. If at all possible do not let the FC go below the SLAM level.
5) After reading the reviews of the hth (walmart) cya I returned the pool store bigger pellet cya for the smaller, more flakey/smaller rocks hth stabilizer (cya) and it looks like it will dissolve much, much faster indeed! It was cheaper also, but I cared more about the faster dissolve. My question is, is it better to put this in socks/shirts/stockings in front of the return or in the skimmer basket? I've seen both advocated. And is it totally okay to squeeze/massage either every so often? I like the sock in front of the return as I worry about the skimmer getting blocked by the shirt/sock. I end up squeezing it all out just to get it over with! Let is sit in the water for a little while then squeeze until it is gone. I am just like that.
6) I brush constantly during slam, but what about vac? siphon vac to waste or vac to filter? i'm confident skimmer wouldn't clog now, but there will be dead algae and seems sand to put that right in the fresh sand lol I am with you about putting that yuck in your pretty, new sand. I would have the hose running and go to waste.
7) psi gauge - remove the plastic nib or not?Not sure what that is-sorry
Thanks everyone that has been or will be helping me! Such a different pool than I have in Florida! Spoke with my Dad that is caring for the Florida pool (using TFP) and it is still crystal and sparkling. Vacuum pressure is back to 100% after he replaced both the PVC ball/manual valves that were leaking air. Expensive but worth it to have a full strength vacuum/bottom drain and no more return line bubbles anymore!
