Proper test kit
Mar 29, 2016
88
Chicago,IL
I ordered a k-2006 kit recently but after further reading it seems the tf-100 kit seems more appropriate. This is my first pool and is a brand new install. I've always had a family pool growing up but never managed the water. I paid $60 for the k-2006 but contemplating spending another $100 for the tf-100 and speed stir. Figured it's cheap considering the investment and will save $$$ in the long run:). Am I on the right track? Should I return the k-2006? Is it worth hanging on too?
The K-2006 will be fine. If you need to SLAM and test a lot, you may want to order extra reagents (FAS-DPD kit) though. Otherwise, the K-2006 will give you accurate results. You should however order the speed stir. That makes mixing with either kit much better. :)
