Thread: Seeking advice re: touch-up paint for pool ladder
    Apr 2008
    StL, MO
    49
    Saltwater pool, powder-coated ladder. Pool (and ladder, and everything else) was installed 9/2007. A couple of minor rust stains on pool ladder, around tread bolts and rubber bumpers. Also a corrosion problem re: the pilot screw on my SAm. No stray current, but I'm going to connect a magnesium anode to my bonding wire by the equipment pad per ChemGeek's advice. I'm hopeful this will prevent or minimize corrosion problems going forward.
    But I'm perplexed about touching-up the rust stains on the ladder. I could use epoxy paint , but don't really want to spend $100/gallon. I could use plain old Rustoleum - sure, it won't last very long (rust spots are submerged) but at least it's a cheap fix I can replicate easily and quickly. Any advice?
    Joe
    Re: Seeking advice re: touch-up paint for pool ladder
    The rust is most likely on top of an intact powder coated surface. You can remove the rust by holding a sock with vitamin C tablets in it against the rust for 30 seconds. If the coating is intact that is all you need to do.
    Of course the screws that rusted need to be replaced, if you haven't done that already.
    Apr 2008
    StL, MO
    49
    Jason, it never occurred to me that the rust might just be superficial. I'll try that after installing the ladder. I already replaced the lone rusted screw. Thanks!
