Thread: How to get wet sand out of filter??
    I am switching from Baquacil to Chlorine. I want to change sand AFTER the conversion to make sure its all out before putting new sand in. How can I get the wet sand out of the filter? I know a shop vac is said to work well for dry sand but is it strong enough for wet sand?
    Also what is a recommended wet/dry vac? Thanks alot!
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Re: How to get wet sand out of filter??
    Most any wet/dry shop vac will do. Keep in mind that the sand is very dense, so you will need to empty the shop vac more often than you might otherwise.
    Round Rock, TX
    529
    When I changed mine, I scooped about half of it out until I could see the drain hole. At that point I just use a garden hose to wash it out the drain hole.
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Both of the above mentioned methods work well I just want to mention that if the filter is fiberglass, be sure to have a long-sleeve shirt on to protect your arms
    Luv& Luk
    -Ted
    Thanks a lot for the replies! So I saw a 6.5 peak HP 16 gallon craftsman wet/dry vac at sears for about $100. Is that enough power for the job? The pool store told me wet sand is almost impossible to get out without hand scooping all of it.
    May 2008
    East of KC, MO
    74
    Quote Originally Posted by mrshowtime3
    The pool stores say a lot of things that aren't true too!!
    27ft Above Ground Pool, 52" walls, vinyl liner
    1hp Pentair pump system
    22.5" Pentair sand filter
    BBB is stocked up!!
    TF-100 test kit
