Thread: Should I raise my CYA?
    triplets&quads's Avatar
    May 2008
    North Carolina
    79
    I feel that my CYA is on the low side. My SWG info recommends 60-80 for CYA. Should I raise it? My FC is holding at 3, day and night. And also, my PH is a tad high. It is between 7.5-7.8. Here are my numbers.
    FC 3
    CC 0
    TA 70 (SWG recommends 80-120)
    CYA 55
    PH 7.5-7.8 (SWG recommends 7.2-7.6)
    SALT 3400
    And I must comment about my son-in-law calling a 'pool guy' to give him advice on his pool. I think the 'pool guy' might have him convinced not to install a SWG or to use BBB for his pool! Boy when I get back down to Florida on Sunday, I am going to do this to my son-in-law !
    I AM LOVING THE SALT WATER AND THE BBB METHOD! 15 yr old 15,300 gal ABG, with 5 yr old liner, 5 yr old AquaTrol SWG, S220T Hayward Sand Filter, 1 1/2 HP 2 speed Hayward Pump, TF100 Test Kit, 11 yr old grandson, 6 yr old grand-quads AND 4 year old triplet grandsons! ~ I AM HAVING FUN NOW!
    Re: Should I raise my CYA?
    Raising the CYA to between 70 and 80 will make the SWG last longer and help you chemistry be more stable.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by triplets&quads
    ..........I think the 'pool guy' might have him convinced not to install a SWG or to use BBB for his pool! Boy when I get back down to Florida on Sunday, I am going to do this to my son-in-law !
    Just in case you haven't seen it, here's waterbear's water balance tips for SWGs
    water-balance-tips-for-a-swg-t3663.html
    You're done SLAMing when:
