Thread: Can't set Pool Pilot above 31%
    Aug 2008
    Southwest New Hampshire
    52
    OK, I know I must be missing something simple here , but I can not set our PoolPilot Digital above 31%. I just opened the pool a few days ago. Boost seems to be working fine. I can switch between cell power 1,2, and 3, but when I am in the regular cycle I can't get above 31%. Salt is at 3100ppm. Is this an issue with cold water temp? Currently reading 56 degrees.
    Thanks!
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    Re: Can't set Pool Pilot above 31%
    Yes, it is because of cold water. When the water is cold they limit the maximum percentage you can set it to.
    Aug 2008
    52
    Thanks, Jason!
    Andrew
