Thread: 1st test with the TF-100 kit
    SE WI
    25
    My kit came today so I had some fun playing junior chemist
    Here's the numbers:
    FC 1.5
    CC 1
    TC 2.5
    PH 7.8
    T/A 150
    CYA about 40 as best I can tell.
    temp 77
    This is a 30' round AG (about 24k gallons)
    Water is nice & clear.
    I obviously need to get my T/A & PH down so I'm adding muriatic acid. Started with 1/2 gallon (all I had left). Depending on how the T/A and PH track, I might be doing some aerating too.
    Any other advice?
    Bob
    30' AG Round, Sand filter, Sta-Rite Aquatools 2HP pump, 4G LQ
    Welcome to TFP and congratulations on your first test!
    I would double check that CC level. If it is really 1 then you should shock the pool (bring the chlorine level up to 15). That will bring the CC down to 0, which is a much better place for it to be.
    Other than that you are looking good.
    SE WI
    25
    Rechecked CC and its 0 now with FC at 2.5.
    I added another gallon of bleach. THat should get me between 4-5 ppm. T/A & PH dropped a little with the muriatic. Need to pick-up & add some more though.
    Bob
