Thread: hayward multiport valve needs replacing??
    Is this the way the inside of the hayward multiport valve is supposed to be? It is missing parts of two channels and I cannot tell if it was made this way or if it is broken.[attachment=0:39y1t09v]multiport valve apr 08.jpg[/attachment:39y1t09v]
    Thanks!
    -tcseibert
    25K IG vinyl, 1 hp, 24" sand, Goldline SWG, 75 gpm
    Salt water rocks!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: hayward multiport valve needs replacing??
    It looks like the track is chipped just above the spot where you can see the glue, about 2:00 in the picture. Is that right or am I just seeing things? The larger space where there is no track is fine, and it looks like even where it might be chipped the gasket is holding on, so you're probably ok (aside from needing a new gasket).
    Yes, I think it is chipped in two places. I have a new gasket, but I've been told both that it needs to be glued and then I've been told it needs to just be set in there with silicone. I don't know what to believe.
    Thanks!
    -tcseibert
    Salt water rocks!
    It's chipped in two places and I'm fine?????
    Thanks!
    -tcseibert
    Salt water rocks!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Oh, I see the the second chip now. No, that's a problem. You'll need to replace the valve. Sorry for getting your hopes up.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Depending on the model, the "key stem assembly" might be all you need to replace, rather than the entire multiport. 8)
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
